I talked to Indy about that and they said it is a known problem and that they can repair the heads. The leaks are all in the same area on each intake runner. In the bowl area above the valve seat near the short turn. You have to rotate the head at just the right angle to see the crack.
The engine builder said he doesn't want to put heads with multiple repairs back on the car so he voted for new castings.
