so I understand this right.
You have a body, no vin, no data tag, no broadcast sheet to prove the number / vin you make is correct other than the last 8 stamped in the core support
IMO< have a state assigned vin put on it and call it a day
As more of the details came forth that's what should be done. Who knows if the original VIN tag is on a rebodied something or not??? Thought it was an original VIN tag that was damaged and he knew where it was, without it or knowing where and what happened to it it will be fraud.
