when i ask for help, i always remember to say "thanks in advance", and respond with a thank you when the question is answered. if i try to answer a question, i really don't expect any praise, or even an answer for that matter. just hoping my answer can help someone in any small way possible.
You guys still aren’t getting it. If you are needing help with something the first thing that should be done is a search. On a search you will sometimes get info from guys that left here or died years ago. If a post goes dead with no solution it doesn’t help someone searching for help months or years later. I probably do 10 Google searches a week and it leads to Moparts posts. Many many times with both good and other times zero info. Good and or bad feedback helps many needing help.
