[quote=340man4ever]I would be interested to know what a Pro Stock engine might have for cranking compression....
Also how many runs before the valve job would need attention typically? Not Pro Stock but comp eleminator in the 90's and it was 15 runs and it motor out for a freshen up.But it was the rings that were the issue.May have changed now with those fancy ring packs that are out there.
