Originally Posted By CMcAllister
Rod length, compression height, rod ratio can be adjusted for a specific stroke and deck height. Are these parameters changed or adjusted for different situations or engine design, component weights, etc., or is there a set combination that has been determined to work best in these engines?
8.800 deck is pretty much standard for all the teams that I know of.
