I just used cheap wheel bearing grease with a brush
that's what I used, that is whats on the die, just been setting up for a while.
I hope you mean lube just the pins, instructions on my JD 32 said to never use lubricants on the forming dies groove, the tube will tend to slip backwards if used.
