2 big advantages of Hydraulics is you can keep it mobile and the bender its self can rotate rather than swinging a 20' stick of tubing across the shop! 2nd one is it is much easier to sneak up on perfect bend say matching a protractor. When doing it manually you end up bending too far most of the time trying to judge the spring back...
