Originally Posted By JERICOGTX
Originally Posted By sgcuda
You will wish you had the hydraulic after ONE bend
Yeah. You're probably right. It will give me something else to strive for.
I've done 3 cages with my bender, all by hand. It's not THAT bad. A workout? Yes. End of the world? No. Now if you were say bending .120 wall CM, THAT is a pain... But it's not needed.
Agree, and for my entire cage I had 10 bends, not a one at 90, 4 maybe 15 degrees, everything else was straight pipe. FC cage would have a few more, but there is a lot of time between bending,fitting and tacking the pipe so you can "rest up". Its not like you're standing there bending all day long.
