So th400 can be built in a SFI case so no shield is needed? I assume an adapter plate of some sort is available for mopar bell bolt pattern? And a spacer on the crank? Will it be bulkier that a 727 with a shield as in floor mods required? And after those extras it will still be cheaper than a full tilt 727? Seriously I am just asking as I need to know for my own build.
Here is ati's price list for help on some of those questions I'm not sure if other companies make them.
http://www.atiracing.com/products/trans/pg/supercase.htm The case is built for removable bellhousings, so you just need to buy a mopar bellhousing.
