Trying to recall what Daty and I talked about when he came over... The goal, IIRC, was to use the MP-type "unsilenced" air cleaner top with the drop base because the OEM base interfered with the TB linkage or something like that. I've got a tad of tweaking to do on my TB lever, too, because it also hits the base of the air cleaner. Easy tweak for me would be to simply lop off part of the lever... it's really tall and set up for the dual cables used on a Dodge Magnum truck application (MP 1000cfm billet 4V TB). I obviously don't need both cables in my stick-trans application. Not sure if Daty can get away with that, though, since he's using a different TB to start with, and is also using a juice trans with a Lokar cable, IIRC.
My main concern at the time was that the 14" More-easy air cleaner wouldn't play well with the smaller 13"? MP unit.
