" fixed Point of the steering componants". Maybe flexing steering box mounts, idle arm flexing or worn, rubber bushings on the strut rod (after seeing wheel stands the shimmy i see on landing is probably attributed to those too). Anycar with that many componants will have alot of slop when added up. IMO
