You could plot out the bump steer and see if a travel limiter will keep it out of the worst of it. I would make sure that the limiter attach to a point that will keep everything in compression (balljoints) and try different amounts to see what you can get away with. Use some form of rubber stop also so it doesn't upset the chassis when it hits the limit. I use old shock biskets from bayonet type shocks.
