My 340 / 378
340 Block 4.100" 3.58 eagle Crank 2.100 eagle sbc H Beam rods Diamond Piston 9.5 comp Edelbrock 63CC Heads CNC ported my MCH Houghs 1.6 roller rockers Solid 243/251 duration @ .050" .550/.570 lift Edelbrock RPM Intake Kevco pan with baffles 750 quickfuel carb
520HP @ 6200 and 490TQ @4500
with more compression this motor should have made 550hp
Nice combo ![](/ubbthreads/images/graemlins/thumbs.gif) Yep, more compression, more lift to use the heads, and probably even a 950 would get it over 550 easy.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
