A 416, eddy headed hydro roller motor at 11:1 with 1.875 headers and a strip dominator will EASILY do 575 at 6000 rpm's. Turn it 6800 with the correct cam and it will go over 600. It will idle at 1000 rpm's.
A solid tight lash roller will do 675-680.
80hp from a solid roller?
Guess I should have added "and 7500" but yes. At this point, if you have all the pieces I would just skip the hydraulic roller. But some guys just don't want to bother.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
