ok to avoid future confusion, I pulled off the arm and attached the brand new moog arm I was gonna use, did not hook up to the center link and it was...worse. in the pic you can see that without the lock nut on I can only get it on this far:
I put the fast ratio back on and without the locknut I can get this far:
