I would have run it up to the machine shop and had them surface it .
Also that brings up a good point , the picture the OP put up shows his dial indicator is not inside the bore of the bellhousing ... at least it looks that way ??? but the picture is small ... if that is the case he isn't really getting an accurate reading...
but probably close enough for a caveman ...
I could not get my set up adjusted so that the indicator was fully centered in the bore but it is inside the bore. The picture was taken looking slightly down and from the left. The part that contacts the bore is as close to dead center as I could get it. Does the set up not look right?
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
