The readings are 0 top and -.016 bottom. Left side was -.008 and right -.009.
The left and right setting are nearly the same, difference is 0.001 or the bell centerline is off 0.0005 left to right. Don't try to change this. The difference between top and bottom is 0.016 or the bell centerline is off 0.008 to the bottom. 0.007 offset dowels should put you right on the money.
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
