Quote: I like the fact that you are trying to compare a wedge to a hemi
two diffrent motors
Two different motors, yes...but from the SAME basic foundation or block dimensions. HEMI - High rpm powerhouse. WEDGE - Lower rpm torque monster. Best battleground is between the 220ft and 1000ft marks (1/4 mi). A good lead margin there, you've won.
the blocks are not the same
if the wedge block was like the hemi block (4 )cross bolt mains
and they kept the max wedge port or even bigger / diffrent head (none hemi )
maybe the wedge would have been better than it is
if you where to compare the hemi to big block chevy it would be intresting
Let's unravel your statements here:
Block dimensions and BORE spacing is exactly the same. They are NOT built on the SAME block!!
They have THREE (3) cross-bolted main caps.
Maxie heads are fine up to 450 ci, maybe 470. 500 or more cubes, think about aftermarket and/or "fully ported" Maxies with bigger valves. Wedges have a WIDE selection of cylinder heads.
Chrysler Wedges are getting BETTER as each year passes.
Comparing a Big-Block Chevy to a HEMI? No comparision ( sorry chevy guys). HEMI can and will rpm in places where "Rat Motors" will never go to. Funny thing though, Ford's 427 SOHC motor could do major strip damage to a Chevy Big Block also! 600+ horses "out-the-box"! After all, it IS a hemi (head type) motor!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
