Re: Hemi vs Wedge
[Re: RUNCHARGER]
#1262537
07/07/12 10:12 AM
07/07/12 10:12 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
Stock castings the 426 has almost unlimited horsepower, the wedge not so much, the heads just do not flow anywhere near what the Hemi's do. Wedge block is good for what, 600HP before it breaks, 426 Hemi at least double that. So you want your wedge to make big power so you need an aftermarket block, heads, rocker gear etc. Same cost as Hemi aftermarket parts. They're both great engines but different. Most people have never driven a Hemi, a stock 440 car still pulls okay when you punch it in high gear, a stock 426 Hemi pulls like gangbusters in high gear and feels like that wedge does in low gear. 440 is a great torque engine, the 426 Hemi is a great horsepower engine.
Sheldon
plenty of 600+ wedges out there. Not sure why 600 hp or 6500 are peoples #'s for a wedge. I guess it all depends on the budget. You can make cheaper, more dependable 10 second wedge that a Hemi. If you want more "top end" w/ a wedge all you need to do is add a little boost. FWIW my 440-6 is still pulling hard at the stripe, it's no where close to "done"
