Quote: Yes, it is possible I was not dialing in the stock front end optimally and yes Rick’s points are valid, and I am also glad to be informed by his and others expertise.
There is no such thing as a “perfect” car. Thanks to our passion for this hobby we innovate to achieve improvement. Starting with the stock gear all the way to developing entirely new assemblies. It is a rigorous ordeal to find a replacement K-frame and suitable LCAs. Replacements are hard to find, expensive and rather banged up. In the end the stock parts ride was harsh and lacking in performance. Everything was replaced, re-bushed, re-aligned.. I was not looking for the opportunity to spend a lot of money, I just wanted more performance and went with the Alterkation. The results exceeded my expectations. ...
What shocks and size torsion bars did you use with your stock setup?
Do you live in a place that is hard to find stock parts?
