Hey if you build the stroker you will be able to run 12 with 3.73 or 3.55 and not much converter. When I say 4.30s are not great for 50 or any miles of highway I know Ive done the Yugo passin you becouse youre spining youre mill 35 to 3800 rpm at freeway speeds.STROKERS MAKE TORQUE torque moves that ugly "street or highway gear better". 10 to 1 is a pump gas motor easily... Big cubes in small package is sweet. If you have the parts you say you have a stroker does not cost as much as many would like to believe..A stroker only needs pistons rods and crank, evey thing else you would need for a non stroker aplication also.Machine work same as non stroker other than the 8 small notches that are easily done by hand at home.Strokers work the nay sayers must not have one or they want one and are scared youre going to get the last one..
