Pete, there is not enough info there to give you an accurate estimate. But, any decent stroker should be able to get you in the 11's, as long as your combo isn't way off. I do think that you would have to shift a little higher than 6000 (maybe 6200-6400), and depending on the tire height, run a 3.92 gear minimum.
