![](/ubbthreads/images/graemlins/laugh2.gif)
My point. You can make a 340 or any SB run it will just cost you a butt load of money. And forget about using one in a 3800 lb B-body. You can run 10's in a heavy b-body w/ a stock stroke 440 w/ good off the shelf heads, small roller or 600ish solid cam, 4000 stall and 4.56's.
Small blocks are fine and yeah they can be fast but at what cost? If you are building a bracket car and looking for 10.90's and don't have a deep wallet I'd think the best route to go is w/ a BB. The guy isn't talking about running 8's spinning his junk to 7500. He wants a weekend beater. Shoot I'd bet w/ a decent tune you could get a 440 into the 10's w/ an old school 509 and iron heads.
I used to have a 380 cu in 11.5 to 1 eddy headed stock block eagle rods that would go 10.70s on pump gas and 9.70s on c-12 and 200 shot.I didn't have alot of money in that setup. Got crank new closeout mopar 500, and got the eddys used 800. So I bought eagle rods and got the machine work done witch is pretty much the same big or small block.So I had about 4500 in whole motor to go 10.70s in a 3350 lb a body.
My stock stroke 440 would run those numbers easy in a-body. Probably do 10.90's in this big pig with a 4bbl, more stall and 4.30's that is a big time modified SB. what gear/stall? Agian any motor can run, just what are you will to pay and put up with? I drive mine to the track and home. 10.9's in any car is going to be easier and cheaper w/ a 440.
