OK - a few updates - the heads are at Shady Dell Speed Shop to get the port work done.
The cam selected will require a 954 spring ( double with damper ). This required a tool steel retainer and 10 degree lock.
The lifters are the COMP 8043 lifters that have the link bars in the front as opposed to the older style 828 lifters. These should require no grinding on the block and since the block is tubed the ability of the lifter to pushrod oil is not going to be used.
