Quote: Don't forget to mention, do you really want your driveshaft spinning at 8000+ rpm? Numerically lower gear rear end with a numerically higher low gear in the trans and a good overdrive keep the driveshaft spinning at something resembling a sane speed and still have a good launch.
I had to read that twice but
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
