The plugs were oil, while some were almost all oil/carbon, others were oil, carbon, with white on the ground strap. The motor was "rebuilt" by the last owner about 3000 miles ago I think. I don't trust the previous owner anymore though. I do not know if the cam was broken in properly but I did take apart the oil filter from 100 miles ago and it seemed fine.
Is it using any oil that you can tell, or is that normal? How many miles to one quart usage of oil? Seems like a valve issue to me. if you get some compression numbers, PM me or post them. I will try to divulge what you've got. The only other way plugs could be this fouled is not from firing much at all to burn off the oil, but for only the right side plugs to be like this is a bit suspicious.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
