Quote: Now I know that I need to use a timing light.
Ok, get the light and set initial timing at 13 degrees advanced at idle with the vacuum disconnected. Degrease the vibration damper and put some timing tape on it so you can see what is going on. Also make sure you have 8 volts at the + side of the coil when then key is in the run position; check this with the engine off.
