Quote: I just got my set-up fired up today. The fan works great! I even blocked the radiator with cardboard so that the temp would go up to 200* and the fan would wind up. When I removed the cardboard, the temp came right down to the point that the fan shut off.
I like this fan and controller combo. We've needed this for a long time.
How load was the fan on "high" to you, with the motor running?
Did you time how long it took to get from 200* till it shut off?
The fan did not seem loud at all to me, but I have open headers right now. It did not take long to drop the temp, but I didn't time it. Even with the rad blocked 3/4s or more, the fan kept ramping up trying to maintain the temp and it took a good while for the temp to get up to 200*ish.
Although I have not had this out of the garage yet, it has excelled at every test I can figure to throw at it.
