Quote: me,65 coronet 440 .030,small solid cam,[.557],otb eddy heads,teamg int.,1000 cfm hp,p/g 4500 conv.,4.86 gear,14x32x15 pheonix slicks,3000lbs race wt.footbrake,leave @ 3,000,shift 6500,10.75 @ 125.with only a 1.52 60 ft.
Did your 60 foots change when you switched over from the Torqueflite Sam ? I feel a bit better knowing that my 60' is real close to yours with my little 8.5 slicks .I guess the Dart is hooking pretty good on the slapper bars to go 1.57 60's with the same weight of 3000 lbs .I really dig that Coronet of yours BTW ...
