Quote: Install the intermediate shaft correctly to put the dist in phase and it's a done deal time and time again.
Are you saying the count of the cam/intermediate shaft teeth is such that moving it over one notch(away from the factory standby of parallel(BB) & towards the front dr intake bolt(SB) CAN move the rotor & therefore the phasing just enough to correct it rather than just moving the rotor the same distance on the other side of the dist terminal?.
