Alan,
what is the set-up of the rest of the motor? Stock cam? auto? power brakes? Does the surging or any erratic running occur at idle? In and/or out of gear? ( if auto ). What ignition are you running? Did you have six pack carbs on there before? And, if so, did they run bad? Hence, the new ones.
What I am getting at is if there's another reason for the surging, like a vacuum leak. I usually isolate the carbs as much as possible when trouble shooting. The car
Troy, that was 5 years ago, I just dug up the thread with a search in hopes that he remembered what solved his issue since I was experiencing the same thing or similar anyway. My set up is above if you have any input.
Careful, your character's showing!
