Is LSA not a result of valve events rather than the other way around?
IMO everything has to be taken into consideration but as a combination requires more duration generally would seem LSA would get wider so overlap wouldn't get out of hand.
Or, another way of looking at it is, 112 lsa with 230 @.050 or 280 @.050. Overlap quite a bit different smile
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700
