Originally Posted by mopar dave
Not interested in cutting the notches. Its currently 12.5:1, would like to keep it around 12.
Isky offers a piston notching kit that you can use with the pistons in the block at TDC to remove as little or as much you want to.
I bought the guides and cutters years ago for 3/8, 11/32 and 5/16 guides and two sies of intake and exhaust valve size cutters, work great up wrench.
I tape off the top of the pistons to the block and ran a vacuum cleaner hose to the port I wasn't using to suck most of the cuttings out as soon as the cutter cut them, work great with no real problems afterwards up work scope
I'm not sure how much a 2.20 cutter removing .045 from the piston top makes measures in CC but I bet it isn't much work scope
