I have always used wallace and thats fwhp with whatever set up you have for weight/mph, always comes out a tad more than the slide rule.....example>
Our '69RR, wedge motor dyno'd@695hp 3800lbs@line, through muffs to rear all mechanical w/pump/alternator, street set up with air cleaner. Wallace shows 10.35@129 as 677fwhp on track...1.42 60's best so far. Which is approx 20hp down from dyno no's which used same carb.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
