Dwayne, with the extension on my dial indicator at the same angle the pushrod runs i measure.400" lobe lift.
You aren’t grasping what I’m asking for. The lifter rise from the base circle when the piston is at TDC during overlap. It will be something like .160”.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
