I was considering using factory style exhaust manifold without heat tubes and heat riser. Also I herd that you needed to grind on your Hemi to get the mini starter to fit I thought if I used the factory manifolds I could use the 440 starter. Also do you know where to purchase the "arruzza mounts" Thanks for all the help Bob Jack
