Because the steering conversion is really designed for cars with an automatic transmission were I running an automatic (or a hydraulic throw-out bearing) at this point I could have simply finished the installation. As I'm using original 1957 clutch linkage there were some changes I needed to make to the adapter plate, cross-shaft frame bracket and cross-shaft.
I pulled the steering gear back out and unbolted it from the adapter plate. Then I bolted just the plate back to the frame drilled the 3rd hole required to finish the adapter installation.
Then came the modifications I needed to make for the clutch linkage. The major issue with the adapter plate was it would not allow the cross shaft to fit. While the plate was bolted on I marked were I needed to make my notch for the cross-shaft.
The second item was the frame cross-shaft bracket attachment. The bracket is attached by 3 bolts....two that screw into captive nuts in frame and the third one was one of the original steering gear bolts. That original steering gear bolt is the one original mounting points the new steering conversion the kit doesn't use due to steering gear interference. The design of the bracket makes that bolt kind of critical to prevent the bracket from bending/breaking. Due to the location of the steering gear on the adapter plate I couldn't simply drill thru the adapter and use a long bolt (that would have been way to simple). I ended up marking where I needed to make the hole so when the plate was removed I could finish drilling and tapping the hole for a piece of all thread when I did the final installation.
Of course the cross-shaft bracket also interfered with the new 3rd bolt and washer used for adapter bracket which required grinding a clearance notch in it.
And then finally when doing the last test fit of the plate after making the modification I found out the cross-shaft grease zerk interfered with the adapter plate requiring it to be relocated about 1-1/2" closer to the engine.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
