Things kind of went to crap for a while since my last post on the 57. I got the front end aligned but hadn't gotten too far figuring out the PS conversion.
A while back I came across a guy who is starting to put together PS conversion kits for 57-58 Dodges and Plymouths. He's apparently using a Ford truck PS gear that mounts on the inside of the frame. He did the prototype on his personal 57 Savoy and was able to send me pictures of the setup. It moves the steering box rearward from where the manual box sits and looks like it will clear everything. The steering shaft and column needs to be shortened and a support bracket added to the lower end of the column but that's all stuff I would have needed to do anyway.
I went ahead and ordered his first kit and it should be here next week. It will be 2 or 3 months at the earliest before I can start installing it however as I'm healing up from wrist surgery but I'll post some pictures of the kit when it gets here.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
