Yep, and I tried the return deal on their hot rod pump and it couldn't keep up and went a best of 9.98 then switched to the MAGNAFUEL 300 and went 9.79......
I don't think the Aeromotive 11203 hot rod/street rod pump flows enough fuel to feed a 9 sec car w/ a return style system. It works fine deadheaded though. I went 9.54 at 140+ mph w/ that pump and a single -8 line deadheaded.
Not likely my Mallory 140 can support a return setup, either. Guess I'll leave it as it is until I consider a fuel system upgrade in the future.
