Why does the fuel get hot? Routing or pump stalling? Pump stall is alleviated by the rear bypass or running the pump on a PWM signal. Routing is easy enough to cure. You will see even most OEM's have eliminated tank return.
Doug
Im sure you realize that efi does not have the same problems as the increased pressure raises the boiling point
And Im not sure how many guys here have ever driven their cars for 8 hours straight across states.
Yes, it gets somewhat warm in Michigan. I drove my barracuda there, i also drove to TX, LA, OK, MO,KS,TN,OH,AR,IN,IL,KY to name a few
