Im 8 up 10 back to tank with reg after the carb. Mallory 140 with their regulator. Been running this setup on past 2 cars for 15 years. No other way I would do it
This is the correct way to do it. Return should be larger than the feed , reg before the carb . This is how mine is done and as prescribed Magna.
