the problem isn't the pump, its the heat under the hood. oem cars are fuel injected so the fuel is under high pressure there isn't a problem with it. as soon as I tried non ethanol gas it was fine or cam 2. the problem is the ethanol. winter ethanol is worse than summer blends. I know a few people having the same issues
