The shot with the radiator hose is the one I wanted to see. It's tight but looks like it works. I am going to try internal for openers but if it doesn't work out, using that hole in the front of the block is the fall back plan.
Sure, internal pickup or the hole in the front of the block is slightly more restrictive than an external line right to the pump cover but it seems windage is the bigger problem rather than oil delivery. I'm hoping one of these will be the right comprimise for a street/strip app.
Valvetrain looks like a future source of entertainment!
