I don't know if such an animal exists or not but you can get sheet metal valve covers and then weld #12 AN bungs on them for screw in breathers or use AN lines over to the core support for a Moroso 3 qt remote breather tank.
AndyF,
Thank you for this info, I bought the 440source welded aluminum valve covers and was wondering how exactly to handle this problem. I appreciate your knowledge and willingness to help people, i wish everyone on this board would follow your example. Sorry to the OP for the hijack
Hey no need to apologize, pick up any ideas you possibly can from any source, it's all good.
I ran AN lines to a breather tank on my Wedge engine back in 2001
Over a period of time, though, I got tired of the clutter underhood and found it was not needed on that engine, tested up to 7000. Instead I went to OEM replacement 1970 era grommets and matching OE style breathers. Those paired up with baffles inside the valve covers is all it seems to need. But...that was a 3.75 stroke engine.....
