7 psi on 93 shouldn’t be any problem at all.
Tough love... get that fitech off of your car and go with a true efi system.
The fact that you camera’d the intake, with no signs of oil, tells you all you need to know about the condition of the rings.
Pull the engine, get it honed, install new rings.
"use it 'till it breaks, replace as needed"
