Originally Posted By Cab_Burge
When you use a gapless ring on the top position it make shte 2nd ring flutter which can and may cause excessive oil consumption at WOT shruggy work
Been there, done that once a long time ago puke No gapless rings since tsk twocents
I've also learn the lesson on to tight of ring gaps runaway Drag race motors run better with looser clearances almost everywhere up
No, a gapless top will not make the second ring flutter. If you used a gapless second ring, you could have made that ring unsettle the top ring, but a gapless top ring won't make a second ring flutter..
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
