Quote: You can cut the timing back 3-4 degrees, but it's not gonna help you out much. You need atleast a 3/8" fuel line - and thats out of the tank. To run in the low to mid 12"s, which is where you should be running, your fuel pump should be able to fill a one gallon can in about 30 seconds - minimum - and thats measured from where the fuel line connects to the carb. Forget what the pump MFG. tells you. You need to actually check it to be sure. Your 60 foot times are off about a tenth and 1/2 also, indicating you have a traction problem.
He has a traction problem alright! He states above that he can't even break em loose in first on the street! The fuel line is the last of his worries. Degree/advance the cam, make sure no vacuum leak.
I agree, check for vauum leaks, and degree cam.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
