Schumacher usually shows where the engine should be located, i.e. it's factory location. I would confirm that first, then if you can move and/or shim things about till all clears. But it is not uncommon, even with TTI's to occasionally need to manually clearance the tubes (bash a dent in them). If you decide you need to go that route I'd look at how some do it with finesse, You tube video or similar.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
