Originally Posted By MuuMuu101
Originally Posted By 67autocross
Are those really TTI shorty Headers? The first tube seem to drop down instead of angling back at around 45 degrees.
They're TTi's...
Yea they are, most TTI shorties I have looked at had lots of space around the box. Even the stock power box clears no problem. Did you use old rubber biscuit engine mounts that may have flattened out over time?
A new iron curtain drawn across the 49th parallel
