Just walked to the garage and measured things out. Resonators are definitely not going on the tailpipes next to the leaf springs. There will be interference. With just tips alone, it seems like I will only extend the exhaust by 2 inches, so like some of you said, it may not do much.
My other option is doing a rear-side exit exhaust which will definitely be interesting. Either I could just extend the exhaust to the side with a 45-90 degree bend capping it off with exhaust tips or I may have enough room to reroute the exhaust off with just a 60-90 degree bend and a resonator (Either Jones Exhaust - https://www.summitracing.com/int/parts/jex-jr25/overview/ or Vibrant Performance https://www.summitracing.com/int/parts/vpe-1792/overview/). If I go to the resonator route, I will probably just have the "cannon" look as I won't have enough room for exhaust tips. Not sure how that will change the sound but hopefully it eliminates drone.
